Discuss Re L: Electromax Combi Electric Boiler Problem. in the Central Heating Systems area at ElectriciansForums.net
Good Morning Forum.
I have an issue with a customers Heatrea Sadia Electromax Combi Boiler, i was wondering if any one had much dealings with fault finding on those units.
Im based in Aberdeen, going on 19 years self employed up here. 6 years ago we installed one of these Electromax Combi boilers whilst rewiring the property, the boiler has never given the owners any problems until recently. The owners reported that the Red alarm light had come on and the boiler would not operate the heating system, water heating is fine but the heating side just enters alarm. There are no other indicators flashing along with this i.e no red flashing on demand. I have visited the property & i went through all the fault finding procedures, i checked that the flow & return valves were open, checked the pressure valve was at about 1.5, checked the 2 3 amp fuses, checked supply's,checked that the pump run light on pcb comes on, basically i have gone through everything i can think of. The thing that has me going round in circles is that when i have visited the property, switched the supply's off & reset the system it has never gone into fault whilst i have been there, the boiler runs fine & no fault materialises, i have sat there for 4 hours whilst the boiler runs perfectly, the pump runs & heating goes through to the radiators, the room stat controls everything fine, comes upto temperature shuts down then starts again when demand calls, but when i have gone, the customer calls again next day to report the same fault. According to fault finding indicator it points to a flow problem, but i just cant track this down & it refuses to enter fault condition whilst im present. Any ideas anyone, have you come across anything like this.
Regards.
Sean.
Just an early morning thought - flow problem occurs once everything is up to working temp? This boiler has an auto bypass valve that is set up during commissioning and perhaps its now duff? Maybe repeat that bit of the commissioning and check it still operates? Even simpler check is take off trv on rad near stat and ensure there is always a flow path. See if problem vanishes. Good hunting !
Good afternoon Wilko.
Thanks for taking the time to reply to me.
Your suggestion of taking off the TRV next to wall clock/stat to make sure there will always be a flow was exactly my thought on last visit, i did this but the system still went into fault alarm later after i had left. I had a look at the bypass valve, it's a little difficult to determine at which point on setting it when the water passes it as the return branch is pretty close to the outlet side of the bypass valve & you can feel heat from both. I have it set at around 3 just now. I was hoping that by removing TRV It would have eliminated any flow problem if there was one.
It's one of those faults that you wish it would happen whilst you are present, but it has only happened after i have left & that's after i have allowed the system to reach temperature & begin again, it's strange everything seems to work whilst im there, radiators warm up nicely, can hear the pump running, pressure gauge sits at 1.5, all the lights that should light up on the pcb beside the tank come on. This one has me going a little nuts.
Regards.
Sean.
Regards.
Sean.
Hi Sean,
I hope all is well. I appreciate this issue was quite some time ago but did you ever identify the problem and manage to find a solution. I believe I have exactly the same issue and it is very annoying!
Kind regards,
Ed
Hi Sean,
Kind regards,
Ed
Good evening Ed.
Ed , yes i eventually found the reason for the fault & it drove me crazy. Ed, we found that there was a problem with the Main PCB Board & we believe it actually stemmed from the date of manufacture. If you open up the casing & remove the top panel also you will find a metal covered sort of control box high up on the right hand side, in side this box you will find the Main PCB Board for the heating controls. Ed once you get this PCB Board open, look along the spade connections until you see one called (From Conn 1 Pump Live) & the one next to it called (To Conn 1 Pump Neutral) now what you will probably find is that the spade connections are actually in the wrong positions, the Live brown wired spade has been connected to the Neutral terminal & the Neutral Blue spade connection has been connected to the Live terminal (Wrong Way Round) If you look on the underside of this PCB Board were those spade connections are you will most likely find that the board has signs of burning at those terminals, just look closely at the board just in front of those two spade connections, i will put money on it its the same problem as we found, we had it on two identical boilers. Ed you will need to replace the Main PCB Board, after that it works fine & has for years now.
Ed here is the part number (Baxi 95615065 MAIN PCB - ELECTROMAX
Part Number: 95615065 If i remember correctly i just done a search online for the part, some heating supplier has them, cost about £55.00
Ed if you have an email address send it through to me & i will send you pictures of what we found. Send to [email protected]
All the best Sean.
Reply to Re L: Electromax Combi Electric Boiler Problem. in the Central Heating Systems area at ElectriciansForums.net
Hi, my wife and I have decided to bite the bullet re the costs of an electric combi boiler in an off-gas grid one bedroom flat where space is so...
As a young man, I was an electrician, but now I'm getting on, I am strictly DIY. I used to have a cheap old 900W petrol generator connected to a...
Good morning Guys Looking for some advice with regard to a current job. Building company I'm doing work for are installing...
I have Curry's Essential tabletop dishwasher model CDWTT115 for nearly five years. Earlier this year my machine have stopped running during a wash...
