Discuss Recessed Light going out after 20ish seconds... in the DIY Electrical Advice area at ElectriciansForums.net
I'm led to believe a failing recessed bathroom light I have is usually due to the thermal protector. However I see none in my lighting circuit; the bulb connects direct to an IBL 5002 50VA transformer.
My question is then is it likely the transformer that is faulty and can I replace it with any similar 50VA transformer? I've already tried a new bulb.
What bulbs are you using to replace the old one? If they are LED it maybe because you need a driver instead of a transformer.
They're halogen.
On the 'lampholder' are you referring to the little white socket that houses the bulb in below picture? Where can I buy these?
https://i.Upload the image directly to the thread.com/rf5b1Uu.jpg
Could be transformer or lampholder and considering how cheap they are you might as well change both. Transformers are available with the lampholder attached.
Also change the lamp when you change the lampholder as a poor connection in the old lamp holder will have damaged the pins of the lamp. If you put a lamp with damaged pins into the new lamp holder then this will damage the new lampholder.
Reply to Recessed Light going out after 20ish seconds... in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
Hello, I've installed a Monsoon Extractor Fan kit today, all is up and running and everything is working with the exception of the LED. When I...
Hi all, No electronic knowledge here. The plug/transformer of a led lightstring is fried. Now I am trying to find a replacement on Aliexpress...
Hello I have recently moved home and I looking to upgrade lighting across the house to LED. In the kitchen I have found that there is installed...
I am sending power to some 5v led lights about 50ft from the transformer. I was going to use some CAT6 direct Burial cable that I kept after a...
