Discuss recommend me an inspection lamp in the Electrical Tools and Products area at ElectriciansForums.net
basically i've been doing a lot of work up in attics and i need a rechargeable light.
I don't really want to spend over £30 but will do if needed.
Thanks,
Aaron
Screwfix do a double 18w fluoro that acts like an emergency light (if you want it to) c.£18 Its about 2 ft long but gives loads of non directional non hot light. Ideal for confined spaces mains or built in battery, and cheap enough that if some flicker DRIVES OVER IT!! it's not that much of a kick in the pocket
Reply to recommend me an inspection lamp in the Electrical Tools and Products area at ElectriciansForums.net
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Hello, I have acquired two FOGLIO wall lamps that I want to convert from wall lights into lamps. I'm not familiar with wall lighting so first I...
