Discuss REG for supply to outbuildings ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There are no regs specific to outbuildings,that'll be why you cant find them. Garages and sheds are not generally special locations,the general requirements of bs 7671 apply....
That is true but info about catenary wire, buried depth of cables and wiring in combustible places (wooden shed perhaps for agricultural. ) are found there
As wirepuller said there are no regs for what you are looking for. It comes down to supply and location regs eg :- 131.8, 132.2, 522.7.10 etc.
also watch out for out buildings with their own water/gas mains or structual steelwork.you cannot take pme to them unless you have correct size cpc to comply with main bonding regs
Reply to REG for supply to outbuildings ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Situation is garden summerhouse fed by own 16A RCBO in consumer unit in garage over 4mm2 (overkill !) SWA . At summerhouse this goes to sockets...
Hi, client wants some sockets and 20a switches moved into high cupboards in kitchen and above 1200mm for tvs etc, the apartment was built in 2016...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
