That's what the main switch is for :)
you just beat me to it ;)
Although I don't disagree I think I would be concerned about not fitting the switch, if only because I would be concerned someone later would object that it wasn't a standard circuit and cause trouble.
I've dealt with this sort of thing on a regular basis, it used to hack me right off but now I just think 'Hell, if I've got to adapt my work to cater for the next electrician who comes and looks at it without really knowing what he's doing then I've no business being an electrician!'
If everyones work had to cater for the lowest common denominator then what's the point? We may as well scrap the regs and just work from the OSG!
I've used those Click 32A grid switches (they're DP, btw) several times over the last couple of years - no issues whatsoever.
Personally, i would always like to see a cooker control switch local to the cooker it's controling. If a DP switch can't be located local to the cooker, then there is not much point in installing one, especially if it's going to be hidden!!
You can now find single back box fitting 45A cooker switches, so it doesn't have to be a full sized or a double back box fitting switch. Don't think i'd contemplate using a SP/DP 32A Grid switch, just don't seem man enough for my liking...
Well, that was my first reaction, too. But then I got to thinking....we're conditioned to see 63A MCB's be exactly the same physical size as 6A ones.... so a separation gap is a separation gap.
They're double width, btw!
