Discuss Removing 2 sockets wired together in the UK Electrical Forum area at ElectriciansForums.net
True, as could driving a car, swimming in the sea etc. Appreciate your concern though...I've got good history changing lightbulbs so ready for the next step
Changing lamps is a relatively mundane jobs that most Householders do themselves on a regular basis, comparing lamp changing to altering and making safe some iffy wiring seems a little cavalier on your part.
Ok the advice has been given so I'm going to knock this one on the head and close this thread.
Reply to Removing 2 sockets wired together in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
A rose in my 1970s kitchen ceiling became loose (one fixing screw had been inserted right on the edge of the hole in the ceiling) and when I...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
