M
mikey12
Hi all i have been asked if i could replace a 12 way lighting gridswitch(correct me if im wrong)in a taxi rank as most of the swiches are broken or not working.These switches supply lights inside and outdoors,this will also involve testing existing cable and outdoor circuits as i believe some could be faulty and could need cable replacement also any ideas or tips would be appreciated.I also believe for the outside lights there is no rcd or rcbo protection at the moment
problem solved ive gave job to spark i know hes happy to go have a look he helps me i help himHi all i have been asked if i could replace a 12 way lighting gridswitch(correct me if im wrong)in a taxi rank as most of the swiches are broken or not working.These switches supply lights inside and outdoors,this will also involve testing existing cable and outdoor circuits as i believe some could be faulty and could need cable replacement also any ideas or tips would be appreciated.I also believe for the outside lights there is no rcd or rcbo protection at the moment
