Discuss Requirements for new ring main in garage in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I need to fit a number of new 13A sockets in my garage to power some new equipment. I am planning to put in a new ring main and a new consumer unit to connect these sockets. The garage is a few metres from my house where the main CU is. Do I have to carry the ring main all the way back to the main CU, or can I put in a length of say 30A steel armoured cable from a new MCB in the main CU to the garage CU?
Any other regulations that I may not have thought of that I need to comply with?
Thanks - Rowan
Reply to Requirements for new ring main in garage in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi all I would like to put some sockets in the attic and keep them on the main house ring main. Am I right in saying I can pull one of the legs...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
