J.C.E
662
165
118
Earth
Under Stairs Cupboard
Install 1x 10way dual RCD metal consumer unit
Install mains gas and water bonding
Testing and certification on completion+ notification to building control
1x d.socket
1x spur for boiler
1x fixed pendant light
Kitchen
4x surface mounted d.sockets- wiring to be installed inside surface mounted white plastic trunking across tiles
1x pendant light + 1gang light switch
Hallway
1x mains powered smoke detector
1x d.socket
1x pendant light+2way switching
1x BT point (router to be situated here)
Porch
2x wall lights with switch inside door- customer to supply 2x light fittings
1x outdoor suitable d.socket
Living Room
1x pendant light
7x d.socket (1 of which being USB)
2x wall lights (switch to be with pendant light switch- 2gang dimmer) -customer to supply 2x light fittings
1x CAT5 data point behind TV (cable to run back to router location)
Dining Room
2x d.sockets (to be on own ring circuit- for future new kitchen expansion)
1x pendant light (re-use existing metal fitting)
Leave coil of 6mm cable from consumer unit- under dinning room floor- for future cooker
1x mains powered heat detector
Back Garden
1x outdoor suitable d.socket (mounted on rear of house wall)
2x wall lights (one on rear, one on side+ light switch inside- customer to supply 2x light fittings
1st Floor Landing
1x mains power smoke detector
2x fire rated LED downlight in white finish+ 2way switching
Small Front Bedroom
1x pendant light
2x d.sockets
1x CAT5 data point (cable to run back to router location)
Front Bedroom
1x pendant light
4x d.sockets (2 of which being USB)
Back Bedroom
1x pendant light
2x d.sockets
Bathroom
1x IP65 rated light fitting- customer to supply 1x light fitting+ pull cord
Utilise existing new fan wiring- but relocate isolator switch to above outside of door
Loft
1x strip light +light switch high level in landing
5m run of swa from cu to a metal adaptable box on garden wall- ready for a shed supply in future
Customer moved out and removed more or less of all furniture- did have to spend 10/15mins to move a few bits in one room.
Had to lift carpets and roll them back out after- but customer to get them cut in themselves after
Customer to get her father to fill/plaster chases/ around sockets
I charged £3950
about right, IMO, possibly as bit on the low side. just done a similar quote without smokes for £3900. smokes are additional option.
Reactions: J.C.E
I think location will see price variance. A quick look came in at £3600 with me. How many men were on the job & how long did it take?
Just for fun i guess lol what about this one- always nice to see if your high or low....
Under Stairs Ground Floor
1x d.socket + 1x fixed pedant light with switch
Install mains gas and water bonding (gas meter by consumer unit, water starts in copper at kitchen)
Testing and certification on completion and after full payment is received
Loft Bedroom 3
4x downlights
4x d.sockets
1x TV point (standard coaxial- to run back to loft storage eves- connection to amp/aerial not included)
Loft Landing
2x pendant lights+1x 2gang 2way switch
1x mains operated smoke detector
Loft Bathroom
4x IP65 fixed downlights+ 1gang switch outside door
1x fused spur+ flex outlet plate for towel rail
1x ceiling mounted extractor fan+ isolator outside door (vented tile to be provided by you)
Loft Storage
1x 600mm strip light+ 1gang switch
Bedroom 1
1x light pendant+ 1gang switch
3x d.sockets
Bedroom 2
2x d.sockets
1st Floor Landing
2x light pendants+ 1x 3gang intermediate switch
1x d.socket
Bathroom 1st Floor
3x downlights+ 1gang switch outside door
1x wall mounted extractor fan+ isolator outside door
1x 6amp feed for bathroom mirror cabinet (cabinet not included)
Reception/ Lounge
4x d.sockets
Kitchen/dinner
10x downlights
6x d.sockets above work top
1x feed for under cupboard light (light fitting not included)
1x cooker circuit+ isolator switch
1x electric hob circuit+ isolator switch
1x s.socket and isolator switch for washing machine
1x s.socket and isolator switch for dishwasher
1x s.socket and isolator switch for tumble dryer
1x s.socket and isolator switch for fridge/freezer
1x s.socket and isolator switch for extractor hood
-All above isolator switches to be hidden in one cupboard with white plastic finish
1x mains operated heat detector
1x fused spur for boiler- supply only
Hall Ground Floor
3x light pendants+ 1x 2gang 2way switch
WC Ground Floor
1x extractor fan+ isolator outside door (duct/vent to outside to be provided by you)
Outside front
2x wall lights+ switch inside front door (light fittings not included)
Outside rear
2x wall lights+ switch inside back door (light fittings not included)
1x d.socket
Plastering and decoration is not included in the cost of this quote.
The cost of this quote is based on all sockets and switches to be brushed chrome raised edge with screws, down-lights to be fixed LED 5.5w warm white fire rated fittings in brushed chrome finish, light pedants to be white plastic. All light switches to be standard on/off switches (not dimmers)
You to supply bathroom cabinet, 4x outside wall lights, and 1x kitchen under cupboard light. These need to be supplied at the start of the 2nd fix stage- to prevent any hold ups of job completion.
You to install wooden noggins in all stud walls where sockets or switches are to be located- at the heights you want them. Then we will fix 35mm metal back boxes to noggins.
......Job won at £5500
prices will change depending on Area, ie South London and Devon way i would guess be dear, Hull and Lincoln cheapest for the same job.. Location Location Location
Reactions: Octopus
I would price that about £5300, but I'm in Manchester so think you're probably a bit cheap for London
funny enough- finished 2nd fixing that one today- won @ £5500- mats come to around £1038 spent 55hours on job. prob got few more hours to do a couple of outside light and kitchen ucl once client has picked them.
J.C.E
Earth
Rewire price check
Electrician Talk
J.C.E,
J.C.E,
