Discuss Room prewired for fans with lights. question about switches. in the DIY Electrical Advice area at ElectriciansForums.net
Hohnrs
I just moved in and had rooms prewired for fans. There are two switches on wall. My new fan has remote controlling fan and light. I removed ceiling fixture which had two bulbs. From ceiling are two sets of black and white wires and on set had ground. My fan only had one black and one white and ground , I connected both whites from ceiling to white on fan. Same for blacks. Connected ground to ground, the fan and light work fine using only 1 wall switch and remote. The motor buzzes a bit. I have already installed these minkeaire fans in other home and the are noiseless. Could my wiring cause buzz? Does my wiring sound correct? Thank you
John
John
John I doubt that your wiring is causing your fan to buzz. If it wouldn’t start that would be a different story
Reply to Room prewired for fans with lights. question about switches. in the DIY Electrical Advice area at ElectriciansForums.net
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
I am installing a ceiling fan in a newly built home. The builders have left the wiring for this purpose. In the electrical box on the ceiling I...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
