Discuss Running cable in pvc conduit. in the Australia area at ElectriciansForums.net
H
hutch6447
Hi all, just a quick question as coming from forces where its all metal conduit I am coming to a part in my installation that is running in pvc conduit and I am using a 4 way conduit box now my question is these cables are running through box horizontally and vertically so can these cables just pass through the box or do they have to be terminated at connector blocks within the 4 way conduit? Thanks
You're only using the 4 way conduit box for the conduit to meet so I would see no reason for it to be terminated. The less connections the better. I stand to be corrected if necessary though.
they will only have to be terminated if you are connecting something to them at the box.
Yeah both cables running straight through if it was connecting well I would use a connection box or junction, but many thanks was just a quick question not really used to working with this pvc conduit thanks guys.
Reply to Running cable in pvc conduit. in the Australia area at ElectriciansForums.net
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
