T
Toneyz
There is nothing wrong to go above and beyond what BS7671 requires.spot-on best comment in this thread so far .
Discuss Sealing a consumer unit entry points?? in the Electrical Forum area at ElectriciansForums.net
Chris was told we are supposed to be sealing all entry points to the CU according The the wiring regulations by the guy running the course but that’s not what’s in the Regulations hence the postThere is nothing wrong to go above and beyond what BS7671 requires.
You are spot on with your opening post. Problem here is the people who tutor the courses and scheme assessors feel the need to gild the lily and hence the blind follow the path.Chris was told we are supposed to be sealing all entry points to the CU according The the wiring regulations by the guy running the course but that’s not what’s in the Regulations hence the post
So true, they should stick to the Regs book and not spread THEIR thoughts on itYou are spot on with your opening post. Problem here is the people who tutor the courses and scheme assessors feel the need to gild the lily and hence the blind follow the path.
Maintaining the fire integrity of a metal consumer unit surely is common sense no?
My jtl guy that did our 18th is also an NICEIC inspector he was very passionate about fire safety to the point we should also be fitting intumescent pads in the back of plastic boxes in stud partitions. A little added protection never hurts anyone and for the sake of ÂŁ2.89 I will continue to do so.
I never once said domestic Cu's do require it, I said I chose to do so. It maybe completely unnecessary, useless, pointless or what ever else people's opinions might be, I don't particularly care. I do what I feel is right and what helps me sleep at night. I lost a relative in a house fire many years back so I'm a little more sensitive to fire risk than maybe most.A larger distribution board in a commercial or industrial setting, might need different considerations; a simple domestic CU does not need all these fire retardant measures.
The regs are there as a guide for at the very least the minimum requirements to make an install safe. If an installer chooses to do something that they feel improves the safety/integrity of an install and it does not violate the standards set, then that's their prerogative.
Some folk might change their view if they got their fingers burnt (excuse the pun)
Body swerve and cop out eh?! I see no reason that you can’t put your response on here for the forum members to read?Give me a call tomorrow we can have a chat
Agreed. And who pays for all this extra unnecessary work - the customer I guess.Was this fire started by an electrical fault?
The point is that while the installer may feel like they are going above and beyond the requirements and making it safer than the minimum standards they are likely achieving absolutely nothing other than wasting time and materials. Also they often make the issue worse by misrepresenting their efforts as a requirement or a safety improvement they are neither.
This leads to problems down the line as people have an annoying habit of believing hearsay and gossip over things written in black and white in the regulations. Just look at the number rof things which get picked up on EICRs which are non-issues.
Guess a bit better next time.I did try calling but after 437 guesses at your number I had to give up
No I will answer in due course that’s not a problem just wanted to talk to you personally as your comment was aimed personally at me and not the issue of fire sealing a consumer unit.Body swerve and cop out eh?! I see no reason that you can’t put your response on here for the forum members to read?
I did try calling but after 437 guesses at your number I had to give up However I’m not really that keen on talking to sassanachs
@DPG Think he wants a date That or some proper trainingCan't really see the need for personal phone calls to be honest.
Ahhh your in Scotland explains a lot.@DPG Think he wants a date That or some proper training
Cant see why he can't answer the questions.
He called us all a bunch of old women, thats personal comment on everyone. Perhaps every member of the forum should ring him
The fire in the control board was caused by a poor connection. The fire at my Aunt's was caused by a faulty appliance.Was this fire started by an electrical fault?
Ahhh your in Englandshire explains a lot.Ahhh your in Scotland explains a lot.
I'm really sorry to read your experiences. Thats awful. I dont think what you and your partner do is overkill. If it makes you feel safer then thats only a positive thing.The fire in the control board was caused by a poor connection. The fire at my Aunt's was caused by a faulty appliance.
I don't disagree with you! there is nothing worse than someone stating something is a requirement when this is not so.
I do what I do for my own peace of mind, whether its a waste of time or not does not concern me because if it helps me sleep at night then its worth the effort.
For example my partner goes around the house and switches all the sockets off and unplugs everything that can be. Its probably over kill but it gives her peace of mind.
yes I shag sheep (but not my own as that would be incest).
Reply to Sealing a consumer unit entry points?? in the Electrical Forum area at ElectriciansForums.net
