Search the forum,
Discuss Sense alarm Fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
having probs with Fire alarm.Its a sense alarm 2 wire,mcp's,detectors & sounders.
Goes into Fire mode,even when only 3 points are on circuit.
Are all their sounders compatible with the system,it's difficult to understand properly ,we have sounders,which are alarm sense,not the sounder & base ones,on their diagram.
Commissioning guy,going round in circles.
From the first quote its states sense alarm 2 wire systems, this could be Fire Sense, 2 wire system...it could be Apollo Alarmsense, Could be Haes 2 wire....so once we get all the info we can go from there
Sorry about the waiting,all ok now,it was a loose smoke detector,not fitting to base properly.
Always the same the worst one to get at,needed scaffold to reach it.
Thanks for all your help.
Reply to Sense alarm Fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
