AJ16
I'm looking for some lights for a kitchen ceiling, as it's exposed beams there is only 50mm air space clearance above the plasterboard which is fitted between the ceiling joists so not enough for a GU10 to fit. I'm looking for some very shallow downlights which will take LED lamps (no heat), what would be good is the type that project down from the ceiling a bit, I know you can get surface fit cupboard lights but I doubt they'd be much cop on the ceiling. Can anybody recommend something suitable?
(If all else fails I'll get some standard open downlights and try to drop them down a bit by fitting into shallow square or round surface boxes)
cheers AJ
Thanks, really good website. The GX53-11W fitting looks perfect, I'll have to try a couple and see how they perform, hopefully they do a warm white. The 9W LED downlight looks good, adjustable and has a 45º beam as well so could be good for other areas with more ceiling depth.
i ordered 8 IP65 downlights with warm white 3watt led lamps on friday afternoon and received them next day 10.00am. was pleasantly surprised to find the fittings were excellent quality, really well made.
AJ16
shallow or surface fit downlights
Australia
AJ16,
AJ16,
