Hello, and thank you for reading this!
I have a question regarding a shielded cable grounding.
I need to wire double shielded cable and eventhough the manual instructions are quite straigh forward I'm not sure what to do. Theres 8 wires inside it and one of them is optic fiber. The fiber wire is assigned to functional earth/shield. To ground the device I'd just connect the shield to the grounging in the control box. What should be grounded: shield, optic fibre or maybe both?
Or am I getting it completly wrong?
The cable will be connected to SICK S300 mini safety scanner, if that changes anything.
I hope someone can help to educate me a little
Thank you in advance!
Izabella
Izabella
