Discuss Short circuit capacity??????? in the Canada area at ElectriciansForums.net
K
KFORDHUNTER
How do you work out the overcurrent devices short circuit capacity in KA, i thought it was just written on it, if you can't find it what do you do then?
HELP!!!!!!!!!
I don't think i explained it that well mate, i'm talking about the main switch for the consumer unit, the value is needed for the cert thats all.
usually printed on ,there are guide tables in the osg for circuit protective devices other than that its time to consult the manufacturer,
can someone add a virus to sparky yorks avatar?:D
it is a bit bright,i was looking at it just and i could feel it sucking my eyeballs out of me head,aaaaaaaaggggggggghhhhhhhhhhhhhhhhhhhhhh
not come accross that one before, its not an protective device is it? if it s just an isolator, why would you need the short circuit capacity?
Shakey need your hekp on this, just got kewtech schedule of test results, the cert you fill in all the test results on, and ther is a box with "overcurrent device short circuit capacity" in KA. I was told this was the capacity of the main switch of the cu, is this right? If not what does it mean. Thanks.
aahhh, i can see now
like i said the main switch is not a protective device
the overcurrent protective device for the installation is the suppliers fuse (often a 1361), they quite often have the Ka value written on them;)
Reply to Short circuit capacity??????? in the Canada area at ElectriciansForums.net
Hi - just after thoughts on this please. I've been doing some testing on a 20 year old MCC. On the original EIC, Ze was reported as 0.04 R, PFC...
Hi all, I have a question regarding the breaking capacity of circuit protective devices. So, the breaking capacity rating of devices in domestic...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
Hi everyone I bought the following device for the purpose of inspection and testing of DPs and its connecions...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
