With your post 'just saying' I thought you meant it as a statement to prove me wrong.
I apologise.
I just find it irritating when people write comments like 'DIY' etc. Its not needed, we all work in the same trade, we are all here to help each other, not compete.
There is of course an exception when a member of the public post about how they changed their light and all the blacks are together and all the reds are together etc... They should be shot.
Someone like yourself does require constructive feedback i agree. However, from the members that give stick - theres so many diy'ers on here now that its just easy to jump on the bandwagon / not read threads properly and hurl out the "get a sparks in" line. Don't think any of it is aimed at you personally to be honest, just people not reading things properly.
Perhaps the manufactures probably realise, that many CU's are located in the properties garage, well millions of them really. So they are advising the use of a local DP isolator, which to my opinion should be in place as a matter of course anyway!!
The OP says he is more than qualified to do some 'domestic' wiring properly, but how will he notify to LABC? Not bother I guess...
Cos when the boiler packs up you can't have a bath/shower/wash or anything and you will stink. Daz
I take it from that that electric showers NEVER have faults! I think with the comparison of with volume of water at the showerhead and the cost, I would take a stab at suffering a cold shower once or twice every ten years.
How am I saying that? When the shower packs up you can still have a bath. Its called not having all your eggs in ONE basket. Daz
I am the house owner and this form of hot water is being installed so that when the boiler packs up (as they so often do...) I will still be able to at least have a hot shower.
I fully understand your reasoning now. When you said that your plumber had recommended an electric shower in preference to his shiny new combi boiler I thought "so the plumber forgot the hot feed to the shower then!". Forming an opinion on an assumption is almost as flawed as getting a succinct answer on here!
No, it's all in hand. A friend of mine who is Part P registered has agreed to sign the work off.
He even visited the house unannounced to have a look.
Did I cover your assumption correctly...?
Another bandwagon jumper...
I bet you wish You did, okay then, why isn't your mate who is going to sign this off not a cowboy then?
1) He is a friend. Friends do other friends things that are called 'favours'. I understand this may not be the correct thing to do in a perfect world but luckily there is no such thing (unless you are a certain forum member).
2) The friend has been to the property (without notice) and checked every part of the install. This would be known as a very conscious act by a guy responsible for signing off work.
3) I will be signing the cert as the Constructor.
Still a problem?
Still a problem?
:veryangry2: yup
