De
Definately a power shower without even knowing the make or model...logic says a 13a fuse would not hold on a 6,7,9 kw shower..step back and think
Yes when you put it like that should have known better, roughly 4.3A for 1Kw would never have worked with a 6Kw shower or higher.
Like I said I am new to it all, its not my core business but seem to be coming into contact with the electrics more often and keen to learn and develop my knowledge a little more.
No tempted to have a little dabble then? What is your contribution to this bathroom renovation, as a matter of interest.
Bath, shower, basin, toilet out. remove tiles, re-plaster, re-tile walls and floor refit new suite with current shower reused.
As for electrical all I have to do is disconnect the current shower,refit same shower once tiling completed
I did a load of courses earlier this year in electrical stuff which got poo poo'd by a number of guys on here as they were not time served apprenticeships and don't mean anything and a waste of money. Personally they were ok for the theory and testing but the practical experience was very limited. Thats the problem with a number of the courses you just do not pick up the hands on experience you need to progress.
Tbh Bear, electrical installation, repair etc is not something which a few "courses" will allow/prepare you to dabble in. What they do encourage, is people to do exactly that....dabble. "It works, so it must be ok". I'm not dissing you, it's just that its is not a profession for amateurs. Having a go tiling or painting or a bit of joinery is unlikely to kill someone or lead to a fire, but electrical work done poorly or by untrained people can and does.
There are a number of sparks here who diss plumbers. I've don the odd outside tap myself, but anything inside my house gets done by a qualified plumber.
No offence Bear, keep up with the tiling, painting (no offence tillers, decorators), but the rest of the stuff can cause damaging water damage or electrocuting/fires if not done professionally.
the above reminds me of a call-out i had once to a shower that the plumber had fitted as a 1 fot 2 replacement. unfotunately for him, the terminals in the new shower were positioned so that the 6mm cable would not reach by 3". he overcame this by twisting a couple of bits of 2.5mm stripped out of some T/E and taped over. i was confronted by a twisted molten mess in the shower and a knackered 30A fuse holder in the old CU. not insinuated that OP would be so daft, but each to his own.
I have a masters Degree in mechanical engineering and level 6 C&G in Hydraulic engineering. Been doing house plumbing on/off for 20 years and fitted bathrooms and kitchens and renovating properties to sell on for the past 15 whilst working offshore lol I'll confess I am more used to 3ph motors star/delta then domestic but the rest I can do with my eyes closed! But I'll be sure to stick to tiling and painting ;-)
Thats just plain bloody stupid. In plumbing I will see runs of 22mm pipe for hot water and someone will size it down to 15mm to fit an isolation valve then open it back up to 22mm just because they did not have a 22mm isolation valve!
In my own house I had 1.5mm T&E running to some spotlights which was fine. Was not until I replaced the insulation I found he had wired them straight into the back of a main 13amp socket in my sons bedroom. The lights were on the 16A MCB in the kitchen someone had tapped into the supply from the cooker to power the under unit lights. I was working offshore and the missus says every time I turn the lights on under the units they pop! Hmm hardly surprising!
Sparky or not doing what I do now some of the things you see from all trades is truly shocking. Appears a case of "out of sight out of mind"
