https://drive.google.com/file/d/1mWK1lmh95uNuc9nIfpHnYhfJ50njeJ30/view?usp=sharing
Yes that looks like the scheme in my original drawing. Note that I have no proof that this system has been used commercially, nor the triac controlled one in the Smith patent. Only that they are possible implementations.
I have found a few more patents.
US2488658 to Ronald Brennen in 1948 claims two windings of different pole numbers, each of which serves as the start winding for the other.
US2564633A to Peter Ziegler in 1948 uses a tricky winding configuration to re-purpose only part of the 6-pole winding as the start winding, under the control of the centrifugal switch.
US2669683 to John Burdett and filed by Westinghouse in 1951 cites both of these and claims the same idea of re-purposing part of the low speed winding but with a different centrifugal switch arrangement.
Read column 1 lines 16-26, where it describes the setup you have just drawn (i.e. with two run and one start windings) as the prior art, also the idea of separate run and start windings for each speed. I haven't yet found these exact configurations claimed anywhere. There are various others that turn up for searches similar to 'multi-speed induction motor' that are not relevant because they are consequent-pole types, or small tapped-winding motors eg. for desk fans that don't have two true near-synchronous speeds.
Have a go searching from that one and see where it leads.
This is all very interesting. I used to be and electrical design engineer specializing in Electric Surface Heating Systems some 20 plus years agog when we lived in UK. Now i have Parkinsons so this is so stimulating Thanks
I found a 2 speed motor, that also has a hi & Lo switch on the back,. I'm assuming that would be their (manually operated) equivalent of the secondary centrifugal switch?
I would say that is the manually operated equivalent of the T106 timer. The motor from which I showed the image of the dual centrifugal switch in post 11, had a similar speed selection switch on its terminal box.
