Does anyone have experience sizing cable tray/ basket and trunking which is used for twin and earth cabling?
The on site guide only provides guidance and factors where single core PVC cables are used.
I am looking for help where twin and earth is used.
What sort of trunking, plastic, metal can't understand why you would want yo run T&E in trunking unless it was for switch drops etc
only cowboys or house bashers put twin in trunking.I was mainly thinking of basket but wondered how trunking would be sized with T&E. I have come across it on some supermarket installs.
I can understand the use of basket for t&e but certainly not trunking. No point in it whatsoever.
I've just finished a 1.5 storey extension on Monday with a cinema room downstaironly cowboys or house bashers put twin in trunking.
I appreciate all the comments but as usual the thread is going off on a tangent. Does anyone know a reasonable method for sizing containment for T & E?
basket or tray, just use trhe rating factors e.g. cables touching/separated, etc. for trunking, use common sense. rate cables according to method B and don't overcrowd the trunking.
Look at page 138 of your Green OSG.
OP until you provide how many and what size t&e you are referring to you will not get a answer. At the minute your question is equivalent to how long is a piece of string.
so use the same tables. you won't be far out. as to how many cables, basically there should be approx. 50% cable and 50% airspace in the trunking. or.................. when you can't get the lid on, you know it's too full.Like I already stated the OSG only provides guidance for single core cables.
Like I already stated the OSG only provides guidance for single core cables. Get your facts right before patronising me.
Maybe re read it perhaps!
Its a generic question. how dies one calculate how many Twin and Earth cables can fit on x size cable tray. Yes I know you can work out the diameter if the cable and multiple, but in reality cables are not butted right up to each other. Is there a factor that is applied.
Yep re read it. Still says the same. For single core cables
like i said. use the tables for singles and assume T/E is poorer at heat dissipation due to it's sheath so derate by a factor that you determine using common sense. BS7671 is not the bible.( even if IET think it is)
What book are you reading? My OSG (Green) talks about other sizes and types of cable. Bottom of page 138.
Have you ever tried applying common sense and finding out for yourself what you need to know?
You have asked about trunking though.
This is what i was getting at.
The normal schedule will always be for lsf singles in supported galv trunking
