Discuss skirting trunking in the Industrial Electricians' Talk area at ElectriciansForums.net
Is it skirting trunking or dado trunking? Have not fitted this stuff a floor level - brittle plastic at floor level sounds suspect to me - too easy to damage. Always fitted it at dado height just above the work surface - computer desks etc.
I would have a carefull luck at the environment itis to be fitted in, if you think it might get easily damage and hence become a safety issue i would tackle the designer about it.
i have seen this stuff smashed by kids playing marbles - yes i am that old!
Will not generally install this apart from running cables in. Did have one customer who insisted on having sockets put in it, in a suite of offices. Did the installation in the first office got some carpet tiles and put them infront of a socket and asked him to plug something in with a moulded plug.
He changed his mind and we ended up putting surface mount at a suitable height, linked by mini trunking to the skirting.
No way round the height issue as far as I can see, unless its a very big skirting!!!!!!
So is skirting trunking illegal? Err no
of course this all depends where you are installing it
heights of sockets comes under part M, and that only applies to domestic dwellings, like part p. So if it was in a school, hospital, etc etc then there wouldnt be a problem
Just to throw a spanner in the works, The Disability Discrimination Act now requires sockets and switches, in commercial and industrial environments, to be set a height accessible for persons with limited reach capabilities, as well as in new domestic situations.
Hi Wayne,
It is an interesting one because according to the regs the installation complies however when I have come across this situation I have pointed out the requirement and also the impracticality of the product and worked within their requirements. The carpet tile and moulded plus I have used a couple of times. the ideal situation is a written quote so that you have a copy of recommendations in writing.
On an existing installation there's not a lot can be done if they say they want the sockets in the trunking.
It's a great industry we work in isn't it?
Tony
Reply to skirting trunking in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, I am currently doing a level 2 (2365). We have been doing trunking factors and I am not sure about if you need to apply the 45% space...
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
I'm converting my garage and have about 15m of skirting being installed which has a groove in it I wish to install a (dotless) RGB led light strip...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Is it acceptable to run mini trunking as shown in the pic? To my mind it would be safer (and slightly less ugly) to have a drop from each socket...
