Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
Is it skirting trunking or dado trunking? Have not fitted this stuff a floor level - brittle plastic at floor level sounds suspect to me - too easy to damage. Always fitted it at dado height just above the work surface - computer desks etc.
I would have a carefull luck at the environment itis to be fitted in, if you think it might get easily damage and hence become a safety issue i would tackle the designer about it.
i have seen this stuff smashed by kids playing marbles - yes i am that old!
Will not generally install this apart from running cables in. Did have one customer who insisted on having sockets put in it, in a suite of offices. Did the installation in the first office got some carpet tiles and put them infront of a socket and asked him to plug something in with a moulded plug.
He changed his mind and we ended up putting surface mount at a suitable height, linked by mini trunking to the skirting.
No way round the height issue as far as I can see, unless its a very big skirting!!!!!!
of course this all depends where you are installing it
heights of sockets comes under part M, and that only applies to domestic dwellings, like part p. So if it was in a school, hospital, etc etc then there wouldnt be a problem
Just to throw a spanner in the works, The Disability Discrimination Act now requires sockets and switches, in commercial and industrial environments, to be set a height accessible for persons with limited reach capabilities, as well as in new domestic situations.
It is an interesting one because according to the regs the installation complies however when I have come across this situation I have pointed out the requirement and also the impracticality of the product and worked within their requirements. The carpet tile and moulded plus I have used a couple of times. the ideal situation is a written quote so that you have a copy of recommendations in writing.
On an existing installation there's not a lot can be done if they say they want the sockets in the trunking.
