C
Connor Hughes
Hi, trying to install a nuetral wire for a smart switch , I’ve drawn a diagram please see photos , could any one confirm If this would be safe, basically , want to pull a nuetral from the light fitting down to the switch , cut the wire behind the ceiling rose containing live nuetral and earth, then using a wire nut connect them all back up but add an additional neutral wire to run to the switch? Is this the correct method
