Discuss Smart wifi switch install with neutral wire in the DIY Electrical Advice area at ElectriciansForums.net
Don7777
Hello all
My house is built 2005. I was trying to install ge smart switch which has 4 wire load ground neutral and line. Ge says it’s simple diy install.
When I remove my existing switch I am not able to identify the neutral wire which according to ge video is white.
How do I find neutral wire in my house ?
I have basic experience where previously I have changed switches in my house and outlets
Attaching the switch pictures
I can only assume the neutral is in the back somewhere, connected through a wire nut. I think I can see a red one in the last photo.
It’s not needed with a standard rocker switch, and just passes through the box, not connected to the switch at all.
Smart switches have electronics in them that require a neutral to operate, so DO need it connected.
I can see two whites at a red wire nut in the last picture.
Reactions: DPG
Thank you
Thank you
I was able to find the neutral wire but now got into another issue. I have bought ge wifi smart dimmer switch and it has support for 3 way light. But while checking the instructions video it’s dying I need to change all the switch in the circuit to make it work.
I was wondering if I install this smart switch and keep the other toggle switch to always on position will it not work ?
Reply to Smart wifi switch install with neutral wire in the DIY Electrical Advice area at ElectriciansForums.net
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
