I know no more than 13amps can be pulled total as the feeding plug won't allow it. Anyone know of any easier way to explain this to my client as the lead was running quite hot so must be near its limits.
I think I'd use that as a starting block, ie 'heat is where fires start'.
Also point out that if the insulation in the extension melts together there will be a short circuit, the fuse should operate and they'll need a new extension lead, but think about what it's doing to the cables inside the walls....
Regulation 5 of the EAWR springs to mind: "No electrical equipment shall be put into use where its strength and capability may be exceeded in such a way as may give rise to danger."
also advise them that in case of fire insurance may not pay out if they can prove they knew what they were doing was wrong,funny how you can tell them facts and they don,t listen,tell them their insurance may be affected and they tend to wake up.Failing that find a good wall and bang your head against it,that normaly works for me
Strange you say that. They are an insurance brokers !
Code of practice states somewhere that 4 way or whatever extension leads should only be used a temporary measure and there should be enough s/o's provided as stated in bs7671, or some thing along them lines
stoutlad,
Guitarist,
