J
James Sutton
Hi All
I Work in commercial buildings around London in one of my jobs i have been asked to re locate a socket in a room the socket is close to the sink and the building manager wants it moved. Problem is its a marble wall. Its a radial cct so thereare other equipment supplied off this cct in other rooms.
Was going to use a though box and extend out of that a run 20mm galv conduit to the opposite wall then into a MK DSO RCD.
Another thing the SO are protected by an MCB iam putting on an RCD socket does the RCD on the SO need to be tested for tripping times.
Any thoughts
JS
Not changing supply cable or going back to dis board so iam thinking Minor Works Cert
Any thoughts
JS
