Search the forum,
Discuss Socket outlet in a toilet? in the UK Electrical Forum area at ElectriciansForums.net
i detect the presence of forum favourite markc123.
good to see him around
i've missed having a little prison bitch.
;-D
You not taken on a new bitch in my absence? I'd of thought you'd of moved onto someone else on the forum by now...
Aye, i'll be back in parts had a really busy period over christmas so not had chance to get on here. But don't worrying, im still 4mm radial'ing :)
Cannot believe i have trawled through 4 pages of blurb re;toilet socket,and nobody said out' regarding part pee...
only just got that - very good. what makes it worse is, just today had to explain to labourer about 'blockbusters' and 'i'll have a p please bob'. now i feel old AND stupid!
This is an eight year old thread you have dragged up, but the short answer is that there are no electrical regulations whatsoever pertaining to an outside toilet, whether or not it has a hand basin in it, other than the general regulation referring to equipment being suitable for the environment it's installed in.
I searched for info on this. Just received new Japanese toilet needing installing in a bathroom. Comes with a 120cm lead with prcd tester close to 13amp plug with instructions to test before use each time. What’s the rules on having a socket in the bathroom furthest position from bath and sink on wall to airing cupboard? Thanks for any advice.
Hi Brian. The prcd is close to plug and has to be checked before the toilet is used every time. See picture. I might be able to get the plug through plasterboard into a socket the other side but it will be very tight going. Will contact Washloo and ask them if they have a lead with a longer lead to the plug end.
Poor design that. Makes it tricky to use other options, such as wiring to an FCU.
Reply to Socket outlet in a toilet? in the UK Electrical Forum area at ElectriciansForums.net
