Discuss Soffit lights, only problem is soffit is concrete in the Lighting Forum area at ElectriciansForums.net
MFS Electrical
Mentor
So was round giving a quote to install soffit lights on a house today no problem some nice IP rated downlights will do I thought, went round to see the job and to give a price and noticed the soffit is in fact made of concreteo_O anyone got any ideas of a fitting to use that won’t look daft? Saw some surface mounted downlights but can’t seem to find any decent IP rated ones that don’t cost a fortune maybe something like these?
Astro KOS Surface Mounted Downlight IP65 in Black - https://cometlighting.co.uk/by-room/living-room/wall-lights/astro-kos-surface-mounted-downlight-ip65-in-black.html
But I was really hoping for something that had a lower profile And price point ;)
I have seen AIB used as a soffit board it’s definitely not that but to be honest it could be an ACM from the ground it certainly looks like concrete because it looks like a concrete paving slab (2 inches thick)there are lots of houses round my way with a very similar looking slab type thing
Reply to Soffit lights, only problem is soffit is concrete in the Lighting Forum area at ElectriciansForums.net
Hi everyone, looking some advice on soffit lighting. I have narrowed it down to these two if anyone could give me any advice or help on which ones...
Hi Guys Got new build coming up where they're wanting some low level wall lights for the staircases. Walls are : Concrete block + dot/dab...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Currently struggling a bit to find suitable lights to fit above a garage door on the soffit. The soffit has a solid joist/beam directly above it...
