Search the forum,
Discuss Soffit lights, only problem is soffit is concrete in the Lighting Forum area at ElectriciansForums.net
I thought I was going mad thinking it was concrete with all the replies :confused: I’m still going to get it tested before I go all gung ho with the SDS I like both of those fittings but as there is no overhang I think I might need something a little more low profile... have you ever installed downlights on something similar?
I’ve seen concrete gutters before, but concrete soffits are a new one on me.
I’ve grew up round here and never thought about it till now but it definitely looks like concrete might have been old finlock type gutters the council just chopped and left
Some of the building methods up here from back in the day were crazy ever tried running a cable in a semi-supporting wall
I might have misunderstood, but the soffit board is usually light weight, I assume that's because it's overhanging. A 50mm thick concrete slab 30cm wide (say) would weigh a ton by the time you went round the house, surely?
Edit - just seen the pics :)
By looking at it I do assume it weighs a ton it doesn’t look like a board at all
I’ll be taking it easy with the SDS in case it cracks and falls taking me with it :tearsofjoy:
Not me personally, but believe it or not I watched someone bore a recess into the soffit then proceed to channel the cable in (unprotected, but who cares up there?). His arguement was that his recess was 150mm deep for the 80mm halogen and the heat would dissipate across the soffit. He may have been right because they were still there in Winchester last I passed (many years ago). But I never did get an answer regarding his boring of holes into a soffit every 90cm weakening it's structure. It was only 40cm wide as I recall.
I was at first thinking of coring holes and recessing led downlights but I didn’t fancy the corer getting snagged above my head and throwing me off the ladder or the soffit raining down around me, not to mention the bill of replacing it/insurance claim
It's not worth the risk, seriously. Buildings that old are fragile and prone to throwing tantrums and falling apart. Don't risk it mate. Please.
Don’t worry that idea was booted out my head almost as soon as I thought of it. The customer has agreed to these fitted high up on the wall as close to the soffit as possible but I really don’t know if it’s going to be the look that either myself or the customer is after...
Reply to Soffit lights, only problem is soffit is concrete in the Lighting Forum area at ElectriciansForums.net
