Discuss solid state relays in the Canada area at ElectriciansForums.net
J
jmtisme
anyone know a good source for a 3pole solid state relay. Not sure what load it has to handle but reckon it would be around 10kw
I think the control voltage would be 110v but would need to check it out
Reply to solid state relays in the Canada area at ElectriciansForums.net
Hi all, I need help/feedback. I am modifying a machine. I have added an aluminium profile frame (enclosure ) to a machine (the machine will be...
Hi Pretty new here, so not sure if this question goes into this thread I am not an electrician; however, I plan to integrate IOT devices and...
I am working within a project that involves access control and video, in a Georgia facility. Another unrelated installer is using properly sized...
HI, Hoping someone can help me here as I am a novice. This is on a vehicle so I hope thats ok but I think it pertains. Long story is I have a old...
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not...
