Discuss Sonoff wifi smart switch connection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello guys,
I currently live in Cyprus and i need some assistance on wiring a wifi touch switch. In Cyprus they follow UK electric system of 3 pins but i dont know about the wiring.
My problem is as follows.
I want to change 2 switches that turn on and off the ssme fluorescent. I unscrewed both current light switch (legrand is the brand) and i saw that except of having the brown wire for L line, it also had in L1 and L2 with different brown wires connected. I know that this is 1 gang 2 way system.
No matter how much i searched to find the sonoff wifi touch switch of 1 gang 2 way, i could not find any. I found only 1 gang 1 way or 2 gang 2 way etc.
Can i do anything with my current purchased switches or is a lost cause? If i bypass the L2 line for example and do not connect it in my sonoff switches, will the 2 way still be working or would i burn the whole place down?
Note that the new switch has an L, L1 and N lines.
Thank you very much
Chris
Reply to Sonoff wifi smart switch connection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
