Discuss Sounder not working on entry in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Steve10
Hi, I have a wired alarm system with a Securitech Active 5 control panel and Lynteck Vortex bellbox. It has worked fine for many years until recently when I noticed this fault.
When the alarm is set and entry is made through the front door entry route, the internal sounder activates after the set delay but the external sounder and strobe don't activate. Any other sensor correctly activates the external sounder and strobe when triggered, it's just the front door that doesn't.
I've gone through the control panel test procedure and everything works fine including the external sounder and strobe. I've done a walk test and the front door sensor is working fine.
Any suggestions as to why this one circuit doesn't activate the bellbox would be really appreciated. Thanks.
Steve
Problem solved - I had been testing the system by simply setting it and leaving the front door open until the alarm went off. I hadn't realised that the door had to be closed for the system to be fully armed and then triggered by the opening of the door.
just when you think you've got yer 'ed round technology, it does a double take and bites you in the arse.
Reply to Sounder not working on entry in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi all, Requesting your help please! I know this is an old system but has been working amazingly for 7 years! I had an engineer out who done a...
My Veritas R8 Excel panel recently developed a power fault and I have replaced the entire unit and reprogrammed it. I can part set the alarm when...
