- Aug 12, 2017
- 14,332
- 20,730
- 3,557,381
- 51
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Been a while since I installed emergency lights as new. Bit rusty.
Now I’ve got a few rooms to wire in a building that are going to be rented out commercially.
I’m upgrading the db, to allow for expansion when other rooms start being worked on.
The customer just verbally told me what he needed, no plans as such.
I’ve brought up the subject of emergency lighting, as he hadn’t mentioned it.... but now I’ve got a few questions for you guys.
It’s down to cost to the customer as to how I design the emergency light circuit.
1. Does it have to have a key switch, or can I Have the emergency lights on a separate rcbo and use the breaker as a test switch? (Or an actual regular switch next to board?)
2. If I put a key switch in each room, would the switch isolate the normal lights as well, or leave the normal lights on while the emergency lights are being tested?
3. I have half a dozen old (unused) non maintained fittings from a previous employment needing used up but they are the old T8 tubes. (Could be 10 year old!) Are the newer LED versions any good? (Quick price check at CEF suggests I just buy new)
I’ll add to the questions if I think of any more
