If you have an open inhibitor circuit that will be a major clue. Close the circuit or put things back as they were.
thanks I will look at that, i will speak to my alarm guy about the pedal start but I asked him to disconnect it all at the time
Yes it may well be . It does seem to be confined to one circuit so I am almost certain it is a supply problem or lack of it, as I have said before.
Check for harnesses being around the hot bits and through bulkheads ect . I still think it is related to interfering with the inhibitor and alarm circuits . Unless you have mice , they like cars that don't move much.
Hi Guys,
Makes for interesting reading... I personally (being a supergeek from the oldschool) would overhaul all the electrics on such a good car!
Wallet permitting, I would ensure the starter motor is genuine Mitsubishi, the solenoid, relays and battery (or at least for the battery what Mitsubishi recommend)... But I wouldnt trust "mates" to know the exact specs of such items, I would go direct to the manufacturer, giving them precise details of your model.
This caught my eye:
Well your relay does not seem to be holding the load for some reason , probably related to supply or earth.
1. If wiring has been tampered with - this could cause voltage supply issue.
2. Since your car has been in use since 2003 (thats about 15 years) the Earth connector may need a good clean. Both the connector and metal it attaches to should be bright. Even though your readings appear to be "normal", readings can be misleading. One failing part in the chain can lead to incorrect supply voltage.
3. Not sure why you need your battery on "trickle charge"? A well-made battery will be charged correctly by the alternator (if the belt has been fitted with the correct adjustment) during normal driving conditions.
Kind Regards NB
@nbwriter Yes you are correct, he does say the car only comes out on nice days , that would not be a lot up here lol., so would explain the trickle charge.
Your other points are valid too , old wiring does tend to just disintegrate from within , and the earths don't.
If the inhibitor has not been traced properly before removal this could cause problems too , as you know fun and games following people.
when you get it started do you have access to a thermal imaging camera? this can point out hot spots in the wiring and terminal connections. as old as the car is its a good bet you may have some corrosion inhibiting the current a bit.
as NB stated the terminals should be clean and bright.
also look for loose connections! they may look tight but if you can move them at all they are too loose.
Hi Guys,
From my experience of working on (older) cars, I suspect gnuuser is on the right track:
Corrosion on terminals (will cause voltage disruption) - I would change them all out! Loose connections is the other culprit. I would systematically ensure all are tight and bright right through the wiring system.
Kind Regards NB :rocket:
Sorry I haven't posted sooner!, well basically I couldn't find the issue so I called a auto electrician out, he said I had lost one of the power sources to the relay so he just added a new power source, we could of looked for the problem but this could of took hours and cost me more money, he said the car worked on the bigger relay as it rerouted how the relay worked , thanks to everyone that posted trying to help! I think I'm going to give the car a well deserved wash now!
