- Reaction score
- 3
Hi all thanks for any help in advance!!
I’m having a issue with a car that will only start if I use a bigger starter motor relay, the car originally uses micro relays from the factory, the car so far has had a new starter motor, new ignition switch and a brand new micro relay none of which have helped or worked, all the currents readings to the starter are normal and the car has quite a new battery.
Kind regards
Buns
Kind regards
Buns
