- Reaction score
- 0
Hello everybody from Germany!
I'm feeling sick with this car, it won't start, just very rarely...please help me out.
Car: Opel Corsa C 1.2 2003 (Vauxhall)
Little background to the car i bought it from a private man who changed the battery and alternator beforehand and for me it seemed the BCM was already changed once too since the case was glued and had configures of a right hand drive car, mine is left hand drive, but he wouldn't have mentioned it. He said that the battery had once showed him something around 16-18V before he changed battery and alternator.
The codes written are diagnosed by OP-Com 1.99 120309a. The car shows sometimes the service lamp blinking while it goes off afterwards completely or comes back up blinking again. Then the car won't start eventhough the starter will try. When turning the ignition off and on several times and the lamp is constantly lighted I may start the car, afterwards most of the time all measurements like rpm or coolant temperature and speedometer will fall off to 0 with the battery lamp and abs lamp coming ON. I had a feeling like when driving longer there weren't ocurring any problems when the motor got warm enough. Now after trying several things with OP-Com, unplugging ABS sensor, unplugging coolant water sensor and even replacing the BCM the codes come back again ALTHOUGH at the first time after resetting and programming everything (ECU,Immobiliser,BCM,Instrument -> that order) the problems seemed to be solved but would occur again after configuring the BCM to the settings my car had before. No problem solved after new BCM...
VIN codes are programmed to the ECU
10 seconds and longer waited after turning ignition off when programmed
Everything programmed succesfully, maybe not 100% right configured with the extras the car has, but wouldn't be relevant at those fault codes i guess
At engine data:
P1615 Wrong Vehicle ID from Body Control Module
P1616 Wrong Vehicle ID from Instrument Control Module
At BCM data:
B3058 - (0 ) Vehicle ID Not Programmed - Present
U2101 - (0) CAN-BUS Maximum Configuration List not Programmed
U2103 - (A) V-Bus Malfunction - Present
U2104 - (A) V-Bus Reset Counter Overrun - Present
U2105 - (0) CAN-Bus no Communication with ECM (Engine Control Module) - Present
U2108 - (0) CAN-Bus no Communication with ABS/TC - Present
BEFORE Resetting and programming modules new: B1485 - (9) Exciter Current Generator Terminal 61 Circuit Open - Not present
At Instrument (probably unrelevant):
174 Coolant Temperature Wrong signal
At engine data:
At BCM data:
- TL;DR
- My modules are not communicating correctly, is it something damaged maybe?
