Discuss strange socket in the Australia area at ElectriciansForums.net
a customer called me and said one socket does not work, popped down and pushed in kewtech tester, no light, ok it does not work, tested voltages between live&neutral, 240volts, 240 volts between live&earth as well, ok i thought the socket is broken, replaced with a new socket, then pushed in the kewtech tester, still no light at all, this really puzzled me, all the volts are there, how come the socket can not work properly?
Your replacement socket may be faulty..... (unlikely but you should eliminate this first)........or I would suspect a neutral problem,high resistance/break.... enough to light your voltage tester but not enough for the kewtech to register.
Reply to strange socket in the Australia area at ElectriciansForums.net
Hi all, Firstly I am new to the forum, so will start by saying hi. I work as an electricians mate, and am joining the forum to gain experience...
I'm moving a socket installed on a lighting circuit (installed by previous owner who was a professional electrician so I assume he knew what he...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi all, I'm wondering if anyone might be able to help. We have a fused switch that controls 4 LED lights next to a power socket which have both...
