Discuss SWA questions, doubting electrician in the UK Electrical Forum area at ElectriciansForums.net
The person "Signing it off" should identify the issues, to which the installer will have to return and fix, followed by a revisit from the "Signing it off" person, who may or may not also be the Notifier.
You may as well cancel the original, pay him off and get someone else who can complete, sign off and notify.
Where are you located, someone here may be able to sort it.?
It is a bit worrying they feel the armour doesn't need earthing because to a competent electrician this is a fundamental requirement.
Totally agree with you. Looks like I’ve been had again then.
I’m beginning to think it would be signed off regardless. I have currently paid just over half but not sure I should pay the rest and then pay someone else to put it all right, surely I should use the retained money (and no doubt add to it) to get it done correctly.
I’m in the Manchester area.
you should give the original sparks the opportunity to rectify it. as it stands, you're on a winner as you have only paid half. talk to him, tell him your concerns. if necessary show him the posts on this thread. if he fixes it and gets it signed off, then pay the balance. if he refuses, don't pay him. you have monies left over to pay someone else. several members in Manc. area should be able to help if needed.
Gave him a chance and just received a reply saying “will leave you to it as I obviously don’t know what I’m doing” so guessing I need to get someone else to sort it. Next issue is whoever I get next is likely to want to start from scratch rather than deal with someone else’s mess I imagine unless they can inspect the ring main and lighting in the garage and be happy with it.
What has made you question the armour of the cable not being earthed because I assume you have limited electrical knowledge.
Just that within minutes of him leaving we had a pretty serious problem with the system tripping when we plugged items in the kitchen. Started googling to try and find out what was wrong and then eventually led me noticing other issues with the work.
I'd put money on it being the Neutral Earth being terminated the wrong way round causing The RCD to instantly trip if somethings plugged in ?
Given this chap has used what sounds like Stuffing Glands to terminate an SWA instead of the correct Glands maybe he wasn't capable of stripping the Armour properly either.
Hi,what were the issues,causing the tripping ?
Still no idea, been blocked now on FB/messenger so need to find someone else to fix.
Just left it disconnected in my consumer for now as don’t fancy any other major issues in the house. Might start ripping all the 4mm SWA out in the next few days to make it easier for someone else to do.
Oh dear. There seems to be more and more of this type of thread on here, a bit concerning the number of jobs being installed to such a poor standard that even the electrically unskilled clients can see it is wrong. It worries me to think about how many bad jobs are just accepted. It's not even like they tried and made a mistake, the wiring is just chucked in any old way.
I hope you can find someone who cares to do the job correctly.
The way I see it is due to competition people are quoting quite low in order to secure the work, they then go away and source all the parts as cheap as possible and even decide to underspec certain things as they’ll probably get away with it in order to then maximise their profit. Obviously not all are like this and a lot of people still have morals and pride in their work, it’s sorting these out from the cowboys that is difficult for the customer.
The work goes ahead and the poor customer doesn’t know it’s not right and expects the price is probably ok and if it works is none the wiser. That would have been me had I not had the tripping issue immediately which is concerning to say the least.
The result now is it’s probably going to cost me more than it would have done to get someone competent in the first place, however I am unsure how non knowledgeable people are meant to avoid this in the first place.
Actually I'm looking at those board pictures once more can you look at the other end of the terminated cables and post photos? Can't help thinking that's not SWA and maybe just Hi Tuff or similar
This end if I understood correctly?
Jeez that's rough.
Nobody is perfect and my own thoughts would have been to give the guy a chance to sort it.
He's blown that opportunity.
Fortunately there are a lot of good tradesmen out there who will do the job properly.
Jeez that's rough.
Issue now is finding someone who might sign it off without starting the whole thing from scratch. What a rubbish situation.
I take it that's under the consumer unit? If so I very much doubt it will reach unless there's an amount of slack to redo this with a correct gland & banjo without either renewing it or a join or isolator of some kind.
Reply to SWA questions, doubting electrician in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
DIYer question. I have a 32 amp supply going from consumer unit in garage to kitchen. It supplies an induction hob only. The cable is easily...
