Discuss Swap a 2 gang dimmer switch for a standard 2 switch arrangement in the UK Electrical Forum area at ElectriciansForums.net
Hi.
In the images. One is a 2 gang dimmer switch and the other a normal 2 gang switch arrangement.
Dimmer 1 controls the main ceiling rose and the second dimmer controls some wall lights.
I'd like to swap out the dimmer entirely for the standard switch only am not 100% sure on the wiring config for the switch. Here's my thoughts:-
2 hot (red) wires incoming. Fit these into com1 & com2 resp.
1 black wire. Fit this into com2 L2 terminal.
1 brown wire. Share terminal com1 and fit to com2 L1 resp.
Does this sound logical enough? Thanks in advance.
Put the brown and red from L1 into one of the COM, doesn't matter which one and the other end of the brown into the other COM. Your red and black go into the L1 terminals separately.
Brill. Works a charm. Thankyou
I've just noticed that switch needs an earth and there doesn't appear to be one unless it is poked in through the back. If no earth you need a plastic switch.
I wonder if theres a 16mm back box behind that and a pattress was put infront to save chiselling out a deeper box for the dimmers @1cookie Do take a look as that switch needs a cpc and there may well be one back there, you could potentially remove the pattress too which would look better.... defo investigate
Reply to Swap a 2 gang dimmer switch for a standard 2 switch arrangement in the UK Electrical Forum area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
I threw away an old knackered light switch and now need to replace it. It had 4 terminals (L1, L2, L3, L4) and is fed by two blue and two red...
