R
Robinson
Right here goes guys....ive got swimming pool which had 2 x 300W 12V Certikin (PU9) Sealed Beam Underwater Lights
http://www.aspectspools.co.uk/300w-12v-certikin-pu9-sealed-beam-underwater-light
...fed from 2 x
Certikin 300W 12V IP65 Light Transformer PU11S...
Certikin 300W 12V IP65 Light Transformer (PU11S) | by Aspects Pools
The client has had someone switch the lamps for some posh Seamaid PAR56 LED Remote controled
LED Swimming Pool Light - Replacement bulb for existing lights, change the exisisting bulb 300w or Halogen bulb to Led,
Question is : The output from the transformers are 150-300w lamps ........the NEW LED's are 12v 25 w consumption and supposedley designed to just replace traditional PAR56 lamp...
can this be so. can i just leave these transformers to run these new LED's ?
They installation that has been done is all up to spec and seems like good job, although we do have a pool of water in one of poolside IP junction wells but gonna sort that....
Im not that up on the latest in LED, and just seems strange to be able to just plug and go with these...I thought maybe drivers and remote receivers might be within the sealed unit of lamp but cant seem to find any details...the 2 links above have some spec...
