Currently reading:
Tell us about your faults!
Discuss Tell us about your faults! in the Australia area at ElectriciansForums.net
K
kung
Hi ALL
Just thought id put this one up for all those faults we find.
heres one to kick it off !
Domestic RCD tripped and wouldnt reset cause was a blown low energy light bulb.:D
There you go now for yours !
worked for a company doing lofts and went to a job where one of the lads(not a spark) had wired the loft light into a jb and when he switched it on the florry strobed, he also found the bathroom light glowed dimly but when you turned bathroom light on loft light went out, he was convinced wrongly that it was a fault with existing wiring,.took me about 2 mins to work out what he had done.answers on a postcard please lol.
It is 'nice' when you (easily) sort someting like that out and can smuggly call 'the lad' a right muppet! :)
went to give a quote for a 3 bedroom rewire. turned out that its a 3 bedroom, with extension at the back and a newly built loft extension. customer wanted to have 3 power showers installed there. 2 were already in, ending in a fuseboard with 10mm tails. one plugged together with a ring circuit. customer wanted some parts of the install be left alone, all work to be done in 4 days, and lots of haggling over the price. I walked off at the end.
Hi. Am after some advice if possible please.
Have moved into an old victorian house and am currently refurbishing it bit by bit. Have included some photo's of what the CU and main fuse are like at the moment. Not a pretty site!! The CU is halfway up the wall but the RCD for it is under the stairs fed by a 10mm cable from the cupboard which is 6 feet away on the other side of the wall. God knows why it is like this!
Am looking at upgrading the electrics to a new split board but just wondering what the best way to go about it would be? I am currently taking a testing and inspection course so that i can sign off my own work but would like any advice if possible.
20120403_153747.jpg20120403_153639.jpg20120403_153809.jpg20120403_153814.jpg20120403_153835.jpg20120403_153846.jpg
As far as the replacement CU is concerned save both your money and time buying a complete CU, just remove the existing MCB's and go all RCBO!! This is a far,far better option than any other RCD configuration CU!!! These dual RCD CU's can be nothing but a heap of trouble when a fault occurs...
I have recently rewired a four bedroom house for a friends parents. One the first inspection visit, I went into the attic, "Throw down the cable with the plug on it" I was asked. I passed it down, stupidly now I know. He proceeded to plug it into a socket outlet on the landing. Swiched on, and hey presto we have lights in the attic.......... After no more than 20 seconds, I shouted "Switch the socket off" I came down, unplugged it and told him never to plug that in again. "why" he asked, "We've always used that for the lights up there". I proceeded to open the plug firstly, 13 amp fuse....... secondly, other end of the flex, another plug containing 13 amp fuse. This plug was plugged into a socket screwed upside down on a roof truss. And to top it all off, this provided the power to two 100watt bulbs in the attic. But the cable running to these lights was speaker wire. It was still hot when I had removed it and showed him......"Thats all I had and its worked fine for years" he said. "I think you have just been very lucky I replied" The jobs finished now and everythings safe and up to regs. He now is the proud owner of a totally rewired house and two energy saving lights in the attic running of the upstairs lighting circuit and operated by a pull cord switch which you operate when the hatch is open. The earth wire attached to the TNS supply was only 4mm and there was no other earthing accept for the cpcs in the cable. I have found that many people think/assume that if the electric works and the telly switches on ok, everythings ok. Especially the older generation.
QUOTE]
I’d get the gravity checked out first, there seems to be a temporal anomaly.
As E54 says fit RCBO’s, do some tidying up and all should be good. Eeerr correction a lot of tidying up. I’ve corrected the anomaly before I put my neck out. where’s the T+E go that’s in the Henley?
I wouldn’t sling that board out if you can get RCBO’s for it.
What's the means of earthing? Looks like it might be a TN-S system, but not an arrangement that I've seen before. Have you measured the Ze? (Maybe not if you're still doing the course.)
If you go for RCBOs (which, I agree, would be good), whether you keep the existing CU or not isn't much of a consideration. A new enclosure with main switch will be about the price of one RCBO, although there'll be the time taken to do the swap.
Where are you located? England or Wales, or elsewhere? ie does Part-P apply where you are?
Thanks for all your replies
Sorry photo's upside down!!!
have already brought the CU when i moved in too long ago to take back. Was looking at moving the CU next to the meter as need to box in the wall where it currently sits.
No have not carried out any testing yet but am expecting problems when i do.
Am located in England so come under Part P
The T+E goes to the RCD under the stairs in the hall, forgot the photo, which then supplies the CU so meggar mess.20120403_153959.jpg
Finally got round to lifting the landing carpet in our new house to paint the skirts and fix the ever present squeaky floorboard when this caught my eye:
0.5mm stranded flex wrapped around the central heating pipes. It's part of the downstairs light loop above the kitchen which has been modified somewhat then just taped up and left. Needless to say it is much safer now.
Gives me an excuse to the the bedroom floor now and have a look, might as well fit some downlighters in the kitchen whilst I'm there as 'I don't know what the rest of the circuit is like dear wife!!!'. I knew I could get rid of the crappy mini GU10 light bar we have... :)
View attachment 11792View attachment 11793
Nice! Glad to see you practice safe isolation in picture two :)
Went to a job the other day coz the outside socket wasn't working strangely I seen fp200 going to the socket that I thought was strange then I uncovered a new type ov underground j/b ha ha a black bag and 15 amp connector
Guys need some advice / ideas...
Background:- I have installed a new TP board off a 200A breaker from the MDB. I was doing some load checks so i could advise the client how much capacity is remaining for new machines and i though i would clamp test the earth to see if there was any activity, when i saw a couple of amps i got a bit distressed so went back to the MDB and clamped the main earth connection from MET to MDB and was reading 14amps - uck a duck i thought whats going on here, anyway with the help of my brother we did some tests in a short time when the factory was quiet.
1. Incoming supply 400A neutral off armourings
2. Incoming supply has separate about 16sqmm earth cable disappearing down into the entry point, not visible outside so not sure if it goes to an earth rod or back to substation.
3. Readings from MET to MDB 14 amps
4. Readings from incoming earth cable was just 1.7mA
5. 10 DBS in total - isolated 9 with no impact on readings.
6. Last DB 12 way was running office computers so did not isolate it but switch off non essential breakers leaving 4 lighting breakers and 2 socket breakers.
7. Switched all all lighting and current dropped dramatically to around 2 amps.
8. Double checked line and neutral loads to this DB and they did show a roughtly 14A difference.
9. Removed the earth connection from MDB to MET but no lights went out and no voltage was present between MET and earth tail from MDB
10. No DBs appear to be cross bonded
At this point i ran out of time and had to put all everything back together but i was left with a couple of thoughts
1. The factory lighting consists of 35-40 6ft double fluorescents of the old switched start type - parasitic loss ????
2. Some of the lights are wired incorrectly neutral to earth but still manage to find a circuit off the strutural steel work when i disconnected the earth that was carrying the current.
Appreciate any thoughts guys, i had to work fast to get the tests done in the time available and have probably missed something perhaps obvious..
Just returned from a job where the customer had some living room lights fitted, after they had been fitted the bathroom light would only work once the living room lights were on. So sparky who did job came back to repair problem. Left and the bathroom light didn't work at all now.
I turn up look in lounge light and there was cable just taped up behind fittitng. Tested bathroom light and no neutral at it. So reconnected cable in other light fitting and all working fine. Can only think the bathroom room light was getting a neutral from the lounge light fitting live so was disconnected.
Saw this today in the outside toilet, 2.5 t+e neatly bent round a 28mm gas pipe,
Sent from my HTC Desire S using Tapatalk 2
Looks like the favoured system of lets lay the cable out then think about the routes after it's gone through several walls and joists followed by the age old phrases of 'bollox' and 'that'll do'. :)
A Garage extension I recently put some sockets and light in, had a JB with armoured cable going to it for the shed in the garden. On inspection, it turned out to be three phase armoured cable with the yellow used as the earth, the black used as the neutral and the red and BLUE both used as a live. none of the wires were sleeved with any colour. When I asked the customer when and who, wired the shed. "A friend who is site electrician. 16 months ago" came the reply. Frightening really, what some people do.
in 2004 I was asked to install lighting and power in and on a large steel framed open sided farm building....usually I would have used plastic tube and singles but on this occasion opted to use multi core armoured as it would be quicker to install than tube...the job dragged on ,then was delayed for lambing and during this period the harmonisation of colour codes came into effect..this was a nightmare when it came to connection time as I now had brown, blue, black, white etc plus red, black, blue and yellow...all of which had to be allocated to various roles.....so allocating blue to a live role is not unusual.
As long as the conductor is properly marked, in this case with red tape...
Reply to Tell us about your faults! in the Australia area at ElectriciansForums.net
