Discuss Testing a boiler fan unit (Keston C40) in the UK Electrical Forum area at ElectriciansForums.net
L
LineProducts
Hi
Any help appreciated!
Boiler error code says fan problem. Plumber wants to replace but at £200 I first want to be sure that the fan is the problem and not the controller.
The fan has two supplies: 230v (which I have tested and is fine) and then a low DC feed from the boiler controller to the fan controller.
Do any of you know how I can power up the fan to isolate the problem?
By pass the controller ????
The fan unit comes with an integral controller. So i need if either the fan or its controller are dead the whole unit needs replacing.
I guess what i need to do is measure if there is any call from the elv dc circuit? There are 4 cables (Y,Or,R,BR) and dont want to risk blowing the main boiler board)
I can only suggest caution, the days when fans were just plain fans have long gone. If it's an electrically commutated motor there's a good chance you'll damage it if you play around by running it with direct mains supply.
Maybe the plumbers forum would be able to give you better advice about the specific fan you have.
Reply to Testing a boiler fan unit (Keston C40) in the UK Electrical Forum area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
Has anyone taken apart their & self repaired it? 2013 Dodge Grand Caravan SXT - Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM...
Hello I have an old timed extractor fan in the bathroom which has stopped working. It has 3 wires which are black, brown and grey. I believe that...
I have a ceiling fan which currently has a remote control for fan speed and dimming the attached lights. We're currently doing some works in the...
