Discuss Testing IT equipment in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
G
gdrms
Is it now the case that all modern IT equipment and power supplies etc can be safely insulation tested at 500v? I have come across conflicting information and although I've done it I'd hate to think I may have caused a subsequent fault. I have a Seaward dvd which says not to do it, only the 100mA earth test, yet my Martindale manual, that's my tester, makes no mention of a problem and I've read elsewhere that equipment 10 years old or less is built to take it so go ahead. There are too many comments elsewhere saying 'it's not safe' for me to be convinced either way and I have a job coming up with a few pc's and psu's included so would appreciate any guidance.​
The IR test automatically connects line and neutral (type 2 test) meaning there's no pd between them, and then tests to earth.
The Martindale tester only has a 3 position switch to select the test current; IT equipment should be tested at 100mA (soft test).
So, as I understand it, on insulation resistance, live and neutral are strapped with 500v passed through to earth so no probs with the voltage getting up to the eqp't so no damage possible? I also see Martindale have revised their manual in that they say the power switch should be on during all tests. Is that the correct method? I can get the purpose when doing IR but is it always necessary for earth bond although, of course it's simpler to always leave it on?
Of course its not necessary to have it on during earth bond test - earth dosn't go through the switch does it !!
But yeah, for IT equipment Class I always test earth bond at 100mA.
Can't see why Seaward say not to do IR on IT equipt. in their DVD - I run two Seaward Supernova Plus(s) - and test menus embedded on these testers include IR @ 500vDC in the test settings.
There are a couple of test sequences which omit IR test and would be utilised on old IT equipment i.e. Pre pre BS EN 60950
It may be an old dvd and it's referring to the older pre 60950 eqp't. I shall press on with it then. Maybe Martindale advise leaving switch on to ensure it's not forgotten during IR test. Another thing, I have recently undertaken a job at a garage workshop and found the Snap On chargers have a 10A fuse at the plug when the charger draws just a few watts. I changed the fuses so far but with so many of them having the same 10A fuse I'm beginning ti think maybe there's a reason for it. Any thoughts on this?
Reply to Testing IT equipment in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
2nd fixing some sockets in an office today and we were talking about high integrity earthing, I've not got a clue what the sockets are going to...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi guys, first time posting, please bare with me! I have an old test chart as shown in the pics that i would like to get running. Everything...
Hi all, just a quick one to ask about an issue I'm having with my EV charger. I'll give a little background first but ultimately I want to know if...
