Discuss Testing RCD on shower circuit in the Electricians' Talk area at ElectriciansForums.net
but 434.2 applies. the cable size is reduced from the tails size ( 16mm?) to the 6mm or 10mm of the shower circuit, so IMO that 6mm ( or 10mm ) should be protected with a suitable overload device. also, if the tails are henley blocked before the main CU, then any fault current is on the DNO fuse.
It's that IQ mate .....................always stirring things like you can't export a PME earth:devilish:
cpc not earthed. broken connection somewhere. do a R1+R2.
IMO "export " is a bad term. to export something means moving it from 1 place to another, when you are not doing that, you are extending it.
Reply to Testing RCD on shower circuit in the Electricians' Talk area at ElectriciansForums.net
I'm interested how you would all approach this one. A 3 phase distribution board on a caravan site, under lock and key. Only warden and manager...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
I live in Australia; you can use a socket tester to test the RCD for the power outlet circuit. Plug device to a 3-pin wall socket, set testing mA...
