Guest viewing is limited
Hi All -
Some advice please on replacing Thermostat and Wiring.
System - Megaflo Water and Heating - Installed 2007.
Original Thermostat - Dial type - Honeywell T6360B
Wire Connections 3
BROWN Terminal 1
BLUE Terminal 2
BLACK Terminal 3
Above Thermostat replaced with Honeywell CM900 (Digital display) Installed 2013 and works fine.
After seeking advice - wired as follows
BROWN Terminal A
BLACK Terminal B
BLUE unconnected
I now wish to replace the CM900 with a Fixed/Wireless Honeywell Y9420H Sundial RF2 Pack
The connection options are as follows.
N
L
1 HW OFF
2 CH OFF
3 HW ON
4 CH ON
The Thermostat is only required for Heating temperature - nothing else.
So the Question is - please -
Of my combination of Blue Black Brown wires - to which terminal should they be connected on the new Sundial
Regards
Martin
The switch wire of the valve controlling the heating connects to the CH ON terminal on the programmer.
Bucks
Thermostat Wiring (Honeywell)
Central Heating Systems
martininnes,
Darkwood,
