The size of the cable supplying a property could be the limiting factor, three phase into domestic properties is common and may well be supplied by 4 x 6mm cable, which would make a single phase supply a bit iffy, the cable could be upgraded but it may be more trouble than it's worth depending on length/difficulty etc.
Edit. OP's probably still in the queue at the electric company office, they're hard work to deal with.
Often in this case the 4 wires are used as two pairs for monophase giving a total x-section of 12 mm2 - which would be counted as 10mm2 - at least temporarily
Three phase common in the countryside here in France - for agricultural use - pumps and so on. People often buy an old farmhouse and find they have 3 Phases - and usually the first thing they do is get it changed to mono - unless they are farmers and want to run motors and stuff ....... The disjoncteur de branchment is effectively an RCBO type "S" - which means it can be set to different sensibilities - but is sealed by the electricity supplier and can be set by an electrician contracted to do so by the supplier - but otherwise it is a criminal offence to break the seal -- I expect it is the same in Spain - from what I can make out here. A 12kVA three phase supply would probably be OK on three phase - 20 Amps per phase - provided the cookers and hotplates were appropriate and could be wired to more than one phase - which is often the case - (especially with induction). I always encourage customers with 3 phase to change to monophase unless there really is an electromechanical thing that is best with 3 phase ....... like a big irrigation pump !
