Discuss Timer and contactor wiring help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I’m installing 5 downlights and 20 x 6W garden spike lights and I haven’t done much timer/ contactor wiring and I was wondering if this diagram was correct.
The lights will only come on from 5:00pm until 10:00pm
Cheers.
I'd go with @telectrix suggestion of adding a photo cell. Not much point in lights coming on when it's still light outside.
Do you actually require the contactor for this setup? Most timer's will be able to handle a lot more load that one you have here, and it appears that everything is on the same circuit.
good point. 10minutes exemption from naughty corner. ;)
Reply to Timer and contactor wiring help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello all, I know this is very simple but I would like some advice please. I am installing a new circuit to feed 5 external floodlights. It is...
Hi guys , I have to break a ring circuit through a contactor with an emergency stop button .. just want to double check my wiring in the diagram...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi, I have ran a light ring off a fused spur with two lights on, each with their own switch (outside and lobby light) I want to put the outside...
