N
Newbyspark
Has anyone had a similar problem. Was called to light that didn't work, someone had obviously had a fiddle after it had stopped working as neutral had not been reconnected properly. Anyway sorted that and got light working but when you turn the light off on the timer switch the light flicks on and off very quickly.Can only assume when the bulb blew originally it damaged switch. Any ideas.
