Discuss Timer switch in the UK Electrical Forum area at ElectriciansForums.net
Has anyone had a similar problem. Was called to light that didn't work, someone had obviously had a fiddle after it had stopped working as neutral had not been reconnected properly. Anyway sorted that and got light working but when you turn the light off on the timer switch the light flicks on and off very quickly.Can only assume when the bulb blew originally it damaged switch. Any ideas.
could be a bit of capacitance in the timer circuitry, discharges through the lamp, causing it to flash briefly.
first fit a normal lamp. see if that cure the problem.
Have you tried the output voltage at the fitting? on and then off?
Had this recently with a very old timer, the customer now has a standard on/off switch!
I changed to a normal bulb and its all works fine. Very strange how it worked for months with low energy bulb then had enough. Thanks for advice. Funny how customer was upset I still charged them £20 to go round and sort it out, even though it saved them over £20 for new switch.
Reply to Timer switch in the UK Electrical Forum area at ElectriciansForums.net
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
