If there's already a tail from the cable sheath to a block[MET] just connect into that, but if it's undersized by current standards I'd ask your local DNO to upgrade it.
Some DNO's use to fit these years ago, however now they have "lost" all data and dont have a record of providing TNS to the property.
I had this in south wales, called DNO - came out and quoted almost £200 to fit a new clamp.
Called NAPIT technical - Advised if readings are within limits its not our issue, make a note on the cert. Advise customer to liase with DNO.
